wildmanbaker
Dec 18, 2013Explorer
dadd, Unless the slide is constructed for windows in the ends, I would forget it. Your slide is probably aluminum framed, and would have a window frame welded into the structure. Without major disassembly to do the job correctly, you would be setting yourself up for problems. As mentioned, try contacting the manufacture for more information.
38,776 PostsLatest Activity: May 14, 2026
