dougrainer
Dec 19, 2013Nomad
Deano56 wrote:
I doubt the factory makes the end panels any different for slides with or without windows for every particular model, but as said already the manufacturer would be able to help
So, you have inside knowledge of HOW RV's are built?? I DO. Every Model and sub model will have different specs for framing. IF the wall has a window or any other outside access door or appliance, they will have radius corners and studs that the window/door/appliance will mount too. They do NOT just cut a hole in the wall and install doors or windows. My point in explaining is NOT to stop someone from doing it, but to explain the risks that they may incur when doing something out of the ordinary on the RV. If the wall has no studs, you cut the hole and then insert wood studs on the 4 sides for support. If it is a radius window(almost all are), you really need the plastic radius corners to install also. Doug
38,776 PostsLatest Activity: May 15, 2026
