As far is it becoming a projectile, I'm hoping that the solution I find will prevent that.
The bracket for the recliner is in kind of an awkward spot, and the previous owners patched the hole in the carpet. I'm not sure If the original bracket is even under there. Would it stick out above the floor a little? The patch job is flush with the floor.
It weighs about 60-70 pikes. Adhesive night be pushing it.
Regarding the wall studs, I'm not familiar with RV construction. What are the studs made of? Are they as solid as the studs in a house?
