pianotuna wrote:
Hi schlep,
The reason is that if you do insulate and then have an accidental freezing it may be MUCH harder to thaw out.
schlep1967 wrote:
I'm not sure why so many are against insulating the pipes in a heated space. It can not hurt anything to do so.
Its no like the insulation is that hard to remove if you should have a freeze-up. If you have power to run lights, you can run the furnace to keep the basement warm. Its a personnel choice, I doubt that it will harm anything. If you really go WINTER CAMPING where the max temp may get up to the 20s, it wouldn't hurt.
