navegator
Jul 17, 2016Explorer
I always knew that as morning dew, cars, patio furniture, even the grass and cement side walks would have moisture.
That has nothing to do with the insulation, it has to do with what side does the moisture laden breeze comes from and the temperature difference from the insulation to the metal frame.
The metal frame shows where it is, if you need to install somethig or drill a hole, you can mark where these are to either avoid or use them.
navegator
navegator
38,782 PostsLatest Activity: Sep 10, 2026
