nkc914's avatar
nkc914
Intellitec BD2
I have a Intellitec BD2 batttery switch panel that has 2 lights and 2 switches for the Coach and the Chassis. My problem is that the light/switch for the Chassis stays on. The switches are momentary the other one works fine. Is this the panel or something else?
Thank you
Mike
99 Coachmen Catalina. Class A
  • Mind are located in the Intellitec Battery Control Center behind the circuit board.
  • nkc914 wrote:
    I am having trouble finding the solenoids, they are not near the coach batteries or under the chassis near the switch. Can anyone give me an idea where they could be. I cannot see anything in the general area under the coach?
    Thank you.
    They are not always by the batteries. They can be up front on the outside firewall. They can be in the entry stepwell area. Usually when you have the BD-2 Both solenoids are located side by side. IF 1 is working, have someone connect and disconnect from the panel and walk around the outside of the RV until you here a solenoid click on and off. Doug
  • I am having trouble finding the solenoids, they are not near the coach batteries or under the chassis near the switch. Can anyone give me an idea where they could be. I cannot see anything in the general area under the coach?
    Thank you.
