down home wrote:
Wonder how hard it would be to install in a Revolution.
It would seem to require a good solid wall for the length of the arm due to the common road and other vibrations.
I assume this is one where the shower head is mounted on a vertical bar and can be slid up/down as desired? Lowe's/Home Depot sells a bunch of different kinds, but I think you have identified one of two potential issues. the bar mount has to be fairly solid, and also the ones I have seen have a very large head and I doubt a RV would have the flow to really use one properly.
I lean the other direction, want a concentrated stream to blast the crud off of me. :)
bumpy
