Ev
Jul 28, 2015Explorer
wildmanbaker wrote:
If you have 6 volt batteries, check the voltage at each battery. If they are both near the same, put a battery charger on them. 10 volts is virtually a dead battery. If you leave them in this state, they will sulfate, and loose some reserve. If they come up in voltage, the converter is bad, as stated before, and needs to be replaced. Converters do not last forever, or even close. I have found that "PowerMax" is about the most dependable brand right now. I have used and tried most of the other brands, but this one seems to be about the most durable.
I have two twelve batteries
38,782 PostsLatest Activity: Sep 10, 2026
