- howdy35Explorer IIMy headlights are fine. I am going to replace the light switch. Thanks, Doug, I didn't know it might be a Ford switch. Will let you know the results.
Wild Bill 888 wrote:
Could also be alternator/regulator. Led headlights are self regulating and may not flicker.
His 20 year old motorhome does not have LED lights. Doug- Wild_Bill_888ExplorerCould also be alternator/regulator. Led headlights are self regulating and may not flicker.
- Your model motorhome should have a FORD Headlight switch. IF the only lights that flicker are the Dash lights, odds are the rheostat for the dimmer in the Headlight switch is bad. The Ford switch is easy to replace. Doug
- DFordExplorerWhat are your headlights doing while the dash lights are flickering? There may be a short in that circuit causing the interior lights to flicker. There's probably an auto reset circuit breaker trying to keep the headlights on.
- Corkey05ExplorerIt could possibly be your dimmer control.
I had that happen and turned the dimmer control to both limits (full bright to full dim) several times .... all was well and hasn't happened since. - pianotunaNomad IIIMore likely a bad ground from corrosion.
38,782 PostsLatest Activity: Sep 10, 2026
