Bobchambe
Jul 28, 2015Explorer
I would get a voltage meter and check the output voltage from your converter.
Should be around 13.5 volts on a 12 volt system.
Are the lights doing the same thing with the engine running?
When my converter went, the lights would work fine when I started the engine, and go dim when I turned it off.
38,782 PostsLatest Activity: Sep 10, 2026
