Ev
Jul 28, 2015Explorer
Bobchambe wrote:
I would get a voltage meter and check the output voltage from your converter.
Should be around 13.5 volts on a 12 volt system.
Are the lights doing the same thing with the engine running?
When my converter went, the lights would work fine when I started the engine, and go dim when I turned it off.
That's what mine does when the engine is on the lights are fine when the engine is off they go dim. Although right now they are bright as can be and the engine is off.
38,782 PostsLatest Activity: Sep 10, 2026
