GGoodsell
Jul 28, 2015Explorer
You may have a battery disconnect switch, usually in the electrical equipment bay. Make sure that is turned on. Even if you are plugged into outside power, if that switch is off you are drawing off the batteries only. I forgot to turn mine on once, noticed lights dimming over 2-3 days and thought my batteries were shot. Once the switch was turned on, all was fine. Check it!
38,782 PostsLatest Activity: Sep 10, 2026
