- wildmanbakerExplorerIf you have 6 volt batteries, check the voltage at each battery. If they are both near the same, put a battery charger on them. 10 volts is virtually a dead battery. If you leave them in this state, they will sulfate, and loose some reserve. If they come up in voltage, the converter is bad, as stated before, and needs to be replaced. Converters do not last forever, or even close. I have found that "PowerMax" is about the most dependable brand right now. I have used and tried most of the other brands, but this one seems to be about the most durable.
- SCVJeffExplorer10v says it all
- ScottGNomadAt 10V, I would disconnect that battery right away. It may have a shorted cell or the converter has already died!
- EvExplorerI am plugged into shore power and they are still dim forgot to mention that
- EvExplorer
ScottG wrote:
Absolute classic signs of a converter dying. Getting the battery checked is a good first step but I would also start shopping for a conv. upgrade.
That's what I was thinking just wanted other thoughts - fourmatExplorer
Ev wrote:
Battery goingDakota98 wrote:
What is your battery voltage ?
The inside meter says 10 volts barely - EvExplorer
The inside meter says 10 volts barely - ScottGNomadAbsolute classic signs of a converter dying. Getting the battery checked is a good first step but I would also start shopping for a conv. upgrade.
- Dakota98ExplorerWhat is your battery voltage ?
38,774 PostsLatest Activity: May 13, 2026
