Goldencrazy wrote:
What kind of disaster? Did they do it and now it has to be redone? The recliners should be easy. The cabinet will require a master cabinet maker with some creativity and will cost considerable bucks. You may want to consider a TV that is permanently mounted or that subs for a computer monitor. 32 inch would be nice size. I use a mac mini on regular tv and it works great with blue tooth keyboard and trac pad. Connects via hdmi.
They tore everything out without bothering to measure and had to put it all back, as it would not fit in the small couch area. So, considering taking out the large couch instead. I want a TV that raises out of a cabinet, as there is a window behind that couch and I don't want to block the window all the time.
