oldgulfc
Oct 15, 2018Explorer
It turned out to be the regulator. In the process I also learned that the new regulator is wired a little different internally. My old regulator would create 120V as soon as it started, The new one requires that you hold the start button 3-4 seconds even if the motor starts immediately to build exciter voltage. It took several phone calls and several hand fulls of pulled out hair to get that figured out. Hope that tid bit helps someone in the future. Thanks again for everyone's input.
38,769 PostsLatest Activity: Apr 04, 2026
