dougrainer
Dec 17, 2020Nomad
rgatijnet1 wrote:
I would guess that this is when your Inverter/CHARGER cuts in to keep your batteries charged. The charger portion of your inverter can draw a lot of power and cause a momentary surge in amps needed. ON my inverter the charging rate is adjustible, or can even be turned off entirely.
I made a mistake on my reply to this post. IF on Gen or Shore Power, there will be NO 12 volt draw caused by a Microwave, since the M/W will be using the pass thru 120 Shore or Genset power. There is NO real heavy 12 volt draw on the batteries once they are fully charged and on Gen or Shore power. Doug
