T18skyguy
Apr 19, 2019Explorer
Just wondering if there is some type of battery isolator that has failed. There usually is a steady current draw from the radio from it's keep alive memory, plus other things as suggested. If you get a clamp-on amp meter you can measure the current draw, you can also measure it with a voltmeter, then while you watch the amp meter pluck each fuse in and out till you see the current stop. That's the offending circuit.
38,780 PostsLatest Activity: Jul 04, 2015
