darsben1
Jul 16, 2017Explorer
If it is the battery disconnect relay it can be serviced. Take the. relay out. find the 4 small screws that hold the "hat" on. Inside will be a big brass washer. remove the corrosion. also clean up the contacts. Lube with a conducting oil or light grease. Put it back together. It has been 3 years since I last had to do this. My failure was not intermittent
