RLS7201
Apr 21, 2015Explorer II
There is a fuse panel under the driver's side dash. It contains the turn signal flasher. The flasher connection is a known problem and some times over heats. I have seen reports of owners cutting the wires loose and installing new ends to connect to the flasher. Also, the turn signal switch on older units such as ours has been known to fail. Easy replacement. Steering wheel does NOT have to be removed. Reasonably priced turn signal switchs on Rockauto.com
Richard
95 Bounder F53
Richard
95 Bounder F53
