chris_diane
Dec 12, 2020Explorer
Just a clarification of caster settings above 5 degrees is only possible with the F53 axle. Shims are installed between the axle and spring allowing greater adjustments for caster. The cutaway chassis (E450, E350) use bushing in the ball joint which can only go to a little over 5 degrees caster. The aftermarket 2 piece bushing can only adjust to 2.5 degrees caster.
38,782 PostsLatest Activity: Sep 10, 2026
