Bill.Satellite wrote:
Your inverter will continue to put out good 110/115V until it cannot do so any longer at which point the inverter will shut down. I have had this happen several times in the past and my 22 year old HH fridge is still running like a top! You really don't need to be concerned.
thanks Bill that's is what I was wondering as I was thinking it may go to a lower than acceptable voltage and be hard on the fridge
But I have set my low voltage to 11.8 so should be good to go
this new fridge only draws like 1.5 amps when running after start up
