chriba's avatar
chriba
inverter and start batteries
I own a 2008 Fleetwood 40x Excursion since new and my 2000 magnum inverter seemed to be making a little more noise than usual, I set the controls to factory default for the inverter in case they had changed some how. This morning there was a strong smell of acid coming off the starting batteries and I noticed a mist escaping from 1 of them.(they are sealed batteries) Has anyone else out there had this sort of situation with batteries and associated equipment. I am looking for advise as to what may have caused this before I replace the starting batteries. Cheers Blake
  • Bud, we have owned this rig since new, the onboard magnum 2000 inverter/charger has always charged both starting and house batteries as far as I know. I am thinking that it is the start batteries that will have to be replaced, but am concerned that there may be a problem with the inverter also? cheers Blake
  • Verify that they are connected correctly.
    Inverter should be off coach batteries, not chassis.
    Could be a bad battery.
