time2roll
Oct 22, 2018Nomad
How many batteries do you have? Need 4 to 6+
You need 2/0 wire from inverter to battery not #2.
Whole house is fine.... also need to set fridge to propane (unless it is a residential style with compressor) and the water heater on propane etc.
If you are just running a tv or charge small items you may only need 350 watts or less. Anything big gets the generator right? Simplifies install. OK to use a small transfer switch on just the branch circuit you need would eliminate the heavy draw items and keep inverter safe from other power sources.
