dodge_guy
Oct 03, 2022Explorer II
dougrainer wrote:dodge guy wrote:dougrainer wrote:dodge guy wrote:dougrainer wrote:
1. Is this compartment sealed? Is it part of the other storage compartments(they share a lot of air space)
2. Do you plan to store items in this compartment?
3. The WORST thing to do with ANY INVERTER,(especially an Inverter/Charger) is to install in a compartment that has NO FRESH air available. There is a reason Inverters have a cooling fan. To cool the Inverter when operating. IF YOU DO NOT HAVE A FRESH AIR SOURCE, HOW WILL THE INVERTER STAY COOL?
4. One of the most common causes of Inverter failure is lack of fresh air to keep the Inverter cool. This is one reason you see a lot of OEM inverter installs mounted to the ceiling of a large storage compartment that allows some fresh air to get to the Inverter. Doug
If the doors are closed, HOW does it get any fresh air??????????????? Besides you now have a dorm refer adding to the heat exhaust. Doug
Yes it’s is sealed. It has the dorm fridge in it. It is the large double door compartment that goes through to the other side.
It does get fresh air, one fan pulls air in, the other pushes it out.
As I said, I have 2 fans pulling and pushing.
From WHERE are you getting the "FRESH" air to Push and Pull? Doug
It pulls air in from outside the compartment. Then the other fan pushes air out of the compartment.
38,782 PostsLatest Activity: Sep 10, 2026
