CA Traveler wrote:
brianseay1 wrote:
The batteries test good, never had a problem until today.
How did you test the batteries? You should do a load test to make sure they are OK. Go to a good battery shop for the test, not a auto store.
Since you let the water get low that increases the chances of a failed battery BTW.
If not the batteries consider disconnecting the Magnum from the battery - be careful and start by disconnecting the battery negative cables. Buy a portable charger and head to FL. Then if you need to ship your unit to Magnum for repair do so from FL.
I used my multimeter to test the batteries and also took them to O'reillys to be tested. Both showed they were good. Now for the stupid question, If I disconnect the magnum, how will I have power? right now when it boots up I get power until it trips out and then it comes and goes.
