CA Traveler wrote:
BTW From a safety point you always remove the negative cables first. If you don't and short the positive terminal to ground nasty things can happen. Then remove the Magnum cable and restore all cables.
BTW The first thing you should have done before wrenching was to take pictures so that you can verify the re-connections.
I did take pictures before removal, That is why I know they are correct. Nothing has changed in the inverter as far as settings go. That's what has got me stumped. I had noticed that the last couple of times that my batteries were not charging fully. Thought that I may have been leaving something on and running them down. Last trip out I had to use emergency battery to start engine. Had to do it the same way yesterday to start engine, that is what got me started to thinking I had bad batteries and now it has just snowballed into bigger issues.
