MrWizard
May 05, 2016Moderator
DRJPPJR wrote:
I am looking for the switch that determines if the 120 volt power is being supplied by power hookup, generator or batteries.
what is the exact problem
no power when on shore power
no power when running the generator
no power to TV and special outlets when on battery ?
when the main TS fails, normally you get shore power and no generator
or maybe no power at all
if the internal TS relay inside an inverter with power pass thru fails
then only those outlets are affected
usually dead , no matter shore or generator
50amp 4 prong service or 30 amp 3 prong service
normally with a 50 amp service, the TS will be in a separate box, with 3 cables, shore, generator, and house some where in between the generator and the shore cord, with my Safari thats an outside bay where the inverter and charger are located
a 30 amp service might have a smaller relay tucked in behind the breaker panel or it could be in a box under a cabinet
38,782 PostsLatest Activity: Sep 20, 2026
