prstlk's avatar
prstlk
Inverter question
We have a 2007 Holiday Rambler DP with an Onan 8500 Generator and an inverter.
The way it is set up through the Magnum Energy panel inside, our batteries do not charge as we are going down the road. The only way to charge them is to start the generator and run it for 2 or 3 hours or plug into shore power.
We called the manufacturer of the panel and they told me that I was to start the coach and go back and look at the panel. If it says “inverting” then it is not charging while the engine is running. This is in fact what it says. He basically told me that some charge while going down the road and some don’t and that it depends on how the MH manufacturer set it up.
Can someone tell me what I would need to do to have the batteries charge while the engine is running and we are moving?
