pianotuna wrote:
Hi Fire Up,
I've seen 193 amps being drawn on the Magnum 3012. When that happens with the engine running it most certainly exceeds the possible output of the alternator.
My microwave draws 1591 watts / 12.8 volts =~ 124 amps. This number also exceeds the possible output from the alternator.
A 2000 watt inverter, if pushed HARD may drop the voltage to 11.5 so the amps drawn would be about 173 amps.
FIRE UP wrote:
I'm not the sharpest tool in the shed but, aren't most modern class A coaches, especially diesel ones, equipped with at least a 160 amp alternator? If that's the case, and, if the chassis batteries are in good shape, then the alternator can provide anything needed to not only "bring up" but, top off, the house batteries while driving.
Now, lets say you have a 2000 watt Inverter/Charger. Typically that would mean that, that inverter is capable of 2000 watts of A/C output, correct? In my basic knowledge of electrical application and the "ohm's law" theory and all that, "Amps x Volts = watts", correct? So, in reverse, Watts ÷ volts = amps, correct?
So, 2000 (watts) ÷ 13 (average volts) = 153 amps. Now, just because the numbers say that a 2000 watt inverter is capable of 153 amps, that doesn't mean it will actually supply that much amperage, correct? So, let's just cut that number in half, for a more realistic number. Say, around 75 amps.
So, with all that goble-gook being said, according to one of the statements above, the panel on the coach, would have to show a supply of at least as high or higher, than say around 75 amps, in order for the load, to overtake, what would be supplied to the house batteries, in order for a "discharge" or "no-charge" set of numbers to be displayed, correct?
Again, I am by far, no expert in any of this. But, the statement that the panel COULD show a house battery NO-CHARGE situation, due to the Inverter/Charger actually inverting THAT MUCH amperage while driving, sure seems highly unlikely to me. And, if that COULD possibly be the case, what in the world, could demand that kind of amperage, on COACH while driving down the road? I mean, even a micro-wave on full throttle for cooking something sure as heck don't draw 75 amps, does it?
Scott
My numbers and calculations are primarily based on some "assumption" and kind of logic. Of course, both ways of thinking CAN be way off. In reality, I've never even thought that, there can be that much draw on the inverter. On ours, a Magnum 2012ME (not year) it's a 2000 watt unit. I guess I've never really taxed my batteries that much.
Scott
