usersmanual's avatar
usersmanual
Inverter 3000 question
Just Installed a 18Cu FT Frigidaire in a 2008 AB and I have a xantrex 3000 inverter system from the factory
It runs great on the inverter system and my question to anyone whom has experience is when the batterys run low and the inverter power drops below acceptable voltages needed to run the fridge what happens
? does the inverter shut off or exactly what protects the fridge from compressor damage from low voltage?
This question only relates to a ""what If"" situation as I plan to make sure this situation does not occur
