BigDaddy1951 wrote:
2007 Winnebago Voyage 35L just upgraded to lithium, new converter etc. Now I would like to upgrade the inverter from the 600 watt to about 2000. The 600 watt powers the front TV, two front outlets, and the rear TV. How hard would it be to power all the 15 and 20 amp breakers on the load center?
Too bad you upgraded the converter. When you installed that, it was the perfect time to upgrade to an inverter/charger/automatic transfer switch !
The I/C/S would make installation SO MUCH EASIER ! Remove converter. Wire DC distribution panel directly to the battery bank via a mega-fuse. Connect the AC distribution panel directly to the output of the I/C/S. Move the shore power cord to the I/C/S. Connect the I/C/S to the battery. DONE ! Even easier to use. Just turn the item you want on.
What is on the 20A circuit ?
