Gene_M's avatar
Gene_M
Inverter usage while underway
Greetings to all. This may or may not be a tough question.
I am presently considering the purchase of an inverter to keep my reefer running while underway. I have a single 12v deep cycle battery. Charging of the battery occurs as follows:
1. Through an IOTA ILC3055 with an IQ4 on the attached DLS55 converter while on shore power,
2. While the 4kW generator is running,
3. While the vehicle engine is running via the alternator and battery isolator.
I would like to hook it up by plugging the 30a shore power cord into a suitable receptacle with a relay that will disconnect the converter when the inverter is in use(details were found here http://www.doityourselfrv.com/rv-inverter-install-diy/ (method 4).
My battery has 850 CCA with 170 minutes of Reserve Capacity, not your true RV, live off the grid battery, it is roughly 70aH. I am trying to make the most of my situation.
My question is this: While underway will the inverter drain the battery or find power from, supplemented by, the vehicle's charging system? or am I overlooking something?
  • My camper has fridge with 4 shelves and separate freezer. Total about 5' tall.
    It takes about 16 amp from 12v battery.
    Yours should be in the same range.
    At one point you might want to consider buying "Kill a watt" meter.
    Very handy unit that will measure almost everything you might need for those calculations.
  • My thanks to you both for such quick responses.
    I failed to include the detail that the refrigerator is propane/120vac. It is a dometic R2652 and I can find no AC power specs other than 120vac, 60Hz. My assumption is for a worst case (?) 350 watts, or a 3aH draw on the inverter. I have not done the math, unsure of it, on what that draw will do on the 12v side.
  • You should measure your refrigerator draw to be more precise, but they don't take much power. Engine alternators those days have 120 amp, while average converter powering fridge will take about 20 amp and depends on the coach temperatures - it will cycle off to some degree.
    The only issue is that the single battery will give you only couple of hr when you stop for long lunch. But than, the inverter will shut itself off with low voltage and fridge with no power will hold cold for few hours before problems start.
  • My question is this: While underway will the inverter drain the battery or find power from, supplemented by, the vehicle's charging system? or am I overlooking something?
    The inverter will drain the battery but your alternator should provide more than enough of a recharge that you will arrive with at least as much of a charge as you left with.
