My Magnum 2000 watt inverter has no output of 110 volts on the output wires. Error light is on and both breakers on inverter are not tripped. Batteries have 13 volts. Any ideas?
The first thing you have to do is clear the error light. There is a procedure in your Magnum operator manual. You will not get any output with the error light on.
You can get an error for a number of reasons, one of them being an over temp condition on the FET's or a battery over temp.
