tinkererExplorerJun 06, 2016Inverter with no output.My Magnum 2000 watt inverter has no output of 110 volts on the output wires. Error light is on and both breakers on inverter are not tripped. Batteries have 13 volts. Any ideas?
MrWizardModeratorJun 06, 2016Disconnect the inverter from the batteries for ten minutesSee if it will reset
Related ContentInverter Bad?Inverter Output Power QuestionInverter installInverter Outputtesting inverter output
