Lurker52
Dec 30, 2018Explorer
Inverter with residential refrigerator
I have recently purchased my first class A. A 2001 Monaco Night DP. The previous owners installed a residential refrigerator. My questions are ones that I know has been discussed before. But I am still kind of confused as to what I need to do.
I have 4 6 volt batteries that provide 400 amp hrs. 200 usable. The rig also has a Xantera 1500 watt modified sine inverter. I tried plugging the frig into the inverter and although it ran when the frig kicked on and off the inverter board flashed and other lights flickered. I guess my inverter does not like my frig. Other things like the tv and micro seem to work ok on the inverter.
Should I get a 2nd small inverter to run the rig or upgrade to a pure sine inverter. The frig is a Whirlpool WRT 108FZDW02. I have had some difficulty finding the specs as to energy usage.
We are not boon dockers but would like to stay a couple of nights here and there and plan on doing some Walmart overnights. Will the inverter/charger keep the frig going and charge the batteries enough while traveling? I know I can turn the frig off but it would be nice to not have to while traveling and an overnight stop. I do understand any extended off grid time will need the generator to recharge the batteries. Solar may be in the future but not now. I will also want to use a laptop and charge a couple of cellphones.
I am also looking at a Victron battery monitor. Any advise on which model would be best for my use would be helpful.
So, should I upgrade to a larger (maybe 2000 watt) PSI or get a small one for the frig and if so what size? Will the rig run the frig/inverter and keep the batteries charged while driving? Will my 200 amp hour batteries run the rig for a couple of day if we boon dock some.
Thanks as always
Thanks as always
