ElDoctor
Dec 28, 2016Explorer
inverter/converter problems?
Hello. I have a 2000 dutchstar with the xantrex freedom combi 458 inverter/charger. it keeps popping the fuse on the inverter when i try to charge my batteries. It hums, getting louder till it pops the fuse. And when I'm on battery power through the inverter, I get noise from my gfci outlets and noise from my elec motors (fans)
I'm hooked up to shore power currently. When I disconnect the batteries to charge with an external charger none of my 12 volt lights ect will work.(120 still works) I'm GUESSING the converter/charger side of my inverter is not working. From what I understand, when pluged into shore power some of the power splits off to the converter to power the 12 volt system. This doesn't seem to be happening with the batteries disconnected. Still GUESSING, that the power isnt reaching or isnt being converted to 12 volt and that I'm running my 12 volt system off the batteries since i get nothing with the batteries disconnected and the batteries seem to discharge too fast considering I'm plugged into shore power.
Also, before the fuse started to blow, while charging, (and the engine batteries disconnected) i get power to my dash system and from what I understand, these are supposed to be two separate systems.
What can I do to check the inverter,charger before I buy a new one. Open it up and take a look? I have a multimeter if that will help.Or maybe I have a short some place else and thats causing the fuse to pop? The batteries are new.
Any help would be appreciated.
