theoldwizard1
Aug 30, 2019Explorer II
wa8yxm wrote:
Ok there are advantages and disadvantages to both methods.
If you have a top notch converter, then it is hard to justify a combination inverter/charger/transfer switch. It is easy, if you are shopping for a new converter. The wiring is SO MUCH SIMPLER !
The larger Samlex units (>2000w) have a separate generator input and a relay you can use to do a remote start on the generator.
