2oldman
Aug 30, 2019Explorer II
Fastfreddy14 wrote:The inverter isn't going to be working in an IC when it has shore power. IC's have switches to turn off anything. With separate components you'll have to do your own transfer switch.
I’m thinking I’ll get two good standalone units based on the information you guys gave me. A PD92xx and probably a small 1000w inverter. This also allows me to shut off the inverter when I don’t need it and not shut off the converter..
Failures happen, no matter what you install. Serious Rving includes having plan Bs for that, like carrying a spare car battery charger. As for inverter failures, perhaps you have a generator. Or, you can carry a small cheap inverter until a suitable replacement is found.
