Groover
Feb 03, 2021Explorer II
Is B-B charger for Lifepo4 lithium batteries needed?
I am thinking about switching from lead acid to Lifepo4 lithium batteries and have noticed that some people advocate using Battery to Battery charger to maintain the lithium batteries when charging from the main engine. I am wondering if that is really needed on a class A diesel and would like to hear from some who are using lithium batteries.
The first argument for the B-B charger is that it helps prevent alternator burnout from overload. I am thinking that a class A with a significant house battery pack of any sort should be prepared for a heavy load and that this reason doesn't really apply to newer class A's. Besides being expensive the B-B charger reduces efficiency and impedes charging, at least up to the voltage that the alternator produces.
The second argument for the B-B charger is that the engine alternator will not fully charge the lithium battery. I don't expect that to be an issue very often and if it looks like it may be an issue I can always fire up the generator and use its charger to top of the lithium batteries. In the summer it will probably be running anyway plus the solar panels that I plan to install will have a controller that will allow a full charge.
Thanks for any feedback on your experience!
