Gjac's avatar
Gjac
Explorer III
Sep 26, 2020
Is CG info available from MFG's
I notice most of the TC's I have looked at on the internet post CG(center of gravity) information. I have not been able to locate this info for Class C's on the Mfg web sites. Nor have I seen any info on UVW weight, or weight on front axles or rear axles. Is there a way to find this info before you buy? Or at least a method to estimate the weight distribution? From what I read it is more important on shorter Class C's.
  • Jack Spratt wrote:
    bobndot wrote:
    Not as important in a 'C' bc the tc sits taller in the saddle .
    Actually it’s more of an aid to make sure the COG is ahead of the axle.
    Yes, my tc’s had COG markers from the mfg. I also remember how crosswinds affected handling on my basement model tc. It was more difficult to operate than my non basement tc , on the same truck.
    I remember crossing some bridges where i thought of wearing a life jacket. :B
  • Not as important in a 'C' bc the tc sits taller in the saddle .
  • I am a retired engineer and I know of no way to know that ahead of time if the manufacturer doesn’t provide it. After I bought my motorhome I loaded it up as good as I could and then had it weighed each axle separately.From that you can determine the CG at least from front to rear. I know of no easy way to measure the height of the CG or even how important that might be.To play it safe I never take the corners so fast that it becomes unsafe.
