cccougar's avatar
cccougar
Is the RV Doctor wrong?
Getting ready to sanitize my tanks and I just came across a video from a speaker at a RV show describing how using bleach is no good. Over time it eats away at seals and such. He recommended hydrogen peroxide.
Now RV doctor, RV Garage and others always mention bleach. What are everyone's thoughts on this?
  • Oasisbob wrote:
    Yes, in time, bleach will surely damage your seals. What's wrong with good old soap and water? That's all I ever use. Why would one want to sanitize the tanks? Probley hard on the dump station enzymes also.
    You would dump soap into your potable water tank? Yuk!
  • Yes, in time, bleach will surely damage your seals. What's wrong with good old soap and water? That's all I ever use. Why would one want to sanitize the tanks? Probley hard on the dump station enzymes also.
  • Ya, if you filled the tank and left it there, but if you hold the level down to "normal" levels and then dump it.
  • donn0128 wrote:
    Never had a problem. I suppose if you were to dump pure bleach in and then pump it through the system you could have a problem. But were not doing that. At the rate normally suggested is just above municipal levels so whats the problem?
    X2
  • Never had a problem. I suppose if you were to dump pure bleach in and then pump it through the system you could have a problem. But were not doing that. At the rate normally suggested is just above municipal levels so whats the problem?
