Gundog
Nov 21, 2020Explorer II
I have had 3 class A motorhomes starting with a 73 Winnebago that was a couple of years ago she had bias ply tires oh what a beating you took until the flat spots were ran out in the tires. I had a 2001 Fleetwood 31' on the workhorse chassis. The good and bad on this MH the engine was a big block Chevy with fuel injection it got a solid 10 MPG and towed a jeep wrangler like it wasn't there. The bad it blew all over the road in the wind it was a white knuckle driving experience. When a truck passed it would first blow you away then suck you back after the truck passed and you got the air wash it would shake. The wind could shift this thing several feet all at once. Quality of build was low entry level.
My current class A is a Fleetwood expedition on a Freightliner chassis and a Cat C7 engine with an Alison transmission. Handling, ride & noise is better it is a much heavier machine than the 01 gasser so I can't say it is more powerful weight to HP ratio. The build quality is better with the Expedition better wood and appliances upholstery Etc.
I would have liked the 01 MH if it had a better build quality and had better handling. I believe some of the handling was the amount of overhang from the rear axle to back of coach. When the wind hits this area of the coach it acts like a baseball bat that coupled with no weight to speak of in this part of the coach creates a problem. When towing the jeep it actually helped the handling which to me also confirmed my assumption.
38,782 PostsLatest Activity: Nov 09, 2020
