Racklefratz
Nov 27, 2020Explorer II
Egor'sRV wrote:
I have always done my own repair and renovation. That may have to change some as I have no experience with diesel engines.
Something I didn't see pointed out here is that if a diesel engine gets the maintenance it requires, as specified by the mfgr, you're not going to NEED to do much work on it. Keep the engine, tranny, and generator oil and filters clean and replaced at the correct intervals, and a diesel will go a lot further than a gasser will before needing anything major. They're built that way, which is why all the over-the-road trucks are diesel-powered.
As you already know, an RV consists of a lot of moving parts, since it's not only a vehicle, but a home as well, with all the appliances, plumbing, etc that goes with that aspect. THAT'S where your DIY experience can really help. If you can do that stuff, you'll be ahead of the game, and you won't have to worry about the dealer's minimum-wage kid doing on-job training on your rig with his little power driver, and stripping all the fasteners in the process.
Good luck with your search.
38,782 PostsLatest Activity: Nov 09, 2020
