Kaz
May 30, 2013Explorer
DonPd wrote:
MapSource will allow you transfer your routes and way points to most all of the Garmin family of GPS's. All you have to do is select the Transfer drop down, have a GPS connected to the computer and select the device. That is all It is to it.
OK, but I read the dezl manual and under compatibility it said: "File Types: Maps and GPX waypoint files from MapSourceĀ®." (Note the absence of "route" compatibility.) So, I called Garmin tech support and asked if the MapSource route transfer functionality worked on the dezl and they said no. Sounds like I need to do some more checking. Which of the newer (larger) Garmin units are you using the MapSource route transfer function? That might help narrow my search.
In any event, though, BaseCamp looks like a worthy substitute, so I'll check that out as well.
Thanks for the info,
Skip
38,766 PostsLatest Activity: Jan 10, 2026
