DonPd
May 30, 2013Explorer
Skip wrote:
OK, but I read the dezl manual and under compatibility it said: "File Types: Maps and GPX waypoint files from MapSourceĀ®." (Note the absence of "route" compatibility.) So, I called Garmin tech support and asked if the MapSource route transfer functionality worked on the dezl and they said no. Sounds like I need to do some more checking. Which of the newer (larger) Garmin units are you using the MapSource route transfer function? That might help narrow my search.
In any event, though, BaseCamp looks like a worthy substitute, so I'll check that out as well.
I know on the Garmin units that do not let you store routes the only thing you can send to them from MapSource are way points. I have changed to BaseCamp and like it. I am thinking of upgrading to one of the newer 7" Garmin's. I now have a Garmin 1450 with a 5" screen.
38,766 PostsLatest Activity: Jan 10, 2026
