wolfe10
Apr 05, 2018Explorer
You need to VERIFY whether this is a starter relay that is continuing to supply power or whether you have a mechanical issue with the starter.
Either will cause the same symptoms.
I would start by doing a check on the electrical supply side (whether the starter relay is continuing to supply power to the starter after key is not in start position).
