elhajj33
Nov 20, 2016Explorer
JimInMich wrote:
Quick search and found a fan cluch on ebay for about $1300 shipped:
Fits Freightliner FLN 2000-2005 with Cummins ISC Engines & Sterling Acterra, L Line 2001-2002 with Cummins ISC.
Of course I dont know anything about diesels, so maybe the above clutch isnt the same your needing, but seems to be the ball park of other clutches I found in the search. $700-$800 markup on the clutch is too much IMHO.
Found the same partnand called freightliner. The fan clutch is two parts: clutch and hub. Clutch is $1000 and hub is 750 from freightliner.
My frustration is the mechanic got very aggressive with me when I started asking questions. I'm not the type to be rude, but I wanted to ask: is the clutch actuallly bad or can we just replace the wiring? What was the root cause and is there more we need to replace? He had not identified what caused the belt to break.
The coach has 16,000 miles on it so it's just a bit odd.
Also, the 14hrs seemed high. I know I need coolant because we overheated and had some spillage. Not sure I need 10 gallons though....
