ncrowley wrote:
The connector between the coach and the toad worked loose so we reattached everything. We checked the continuity and it all looks good. However, the right turn signal is not working. Everything else is. Are there any hints about what we should look for?
Not sure which connector you mean. Was it the pigtail that came loose from the socket or did the socket come of the coach or car? After trying most everything in my history I have resolved this twice by opening the connectors on the ends of the pigtail and securing them and then either wrapping them with electrical tape (not much room to do a good job) or potting them in silicon so they cannot short. I secure the plug at the tow'd by using a velcro strip from the cord to the tow adapter. This reduces the pressure on the connection and prevents the socket from dragging on the road and being destroyed.
