ncrowley's avatar
ncrowley
Explorer II
Nov 09, 2014
Issues with Toad Pigtail
The connector between the coach and the toad worked loose so we reattached everything. We checked the continuity and it all looks good. However, the right turn signal is not working. Everything else is. Are there any hints about what we should look for?
  • I would start by checking for voltage at the connector. If there is no voltage there, I would check the fuse for the right side of the TV. If the brake and tail lights on the right side are not working then I would check the ground on that light. JMO
  • Go ahead and check the bulb,this is a prime opportunity for it to have burned out!!!!Murphys Law!!!
  • We spray the connectors with electronic contact cleaner regularly. Seems to work for us.
  • 1. The pins (male side) of the connectors often have a split cut into the pin. After many uses, the two halves of the pins move together and do not put sufficient pressure on the receiving socket. With the power off to the connector, use a small knife to gently pry the two halves of each pin apart very slightly. This has cured a problem on mine several times.
    2. Most of the cords have connectors at each end that can be disassembled. I've found some of the connectors loose (screw terminal inside the connector) even on a new cable.
    After the above tips, I think you're down to playing detective with the trusty multi-meter.
    Fred
