murraymcleod wrote:
You say it works like the dash heater, meaning hot radiator water flows through a heat exchanger at the rear of the coach? And it will also heat up water in the hot water tank, when turned on?
Yes. You have second heater core under your bed. Be sure to check the lines, which run all the way back from the engine, and maintain them on a regular basis. You also have "Motor Aid" hot water heating which routes engine cooling water to a heat exchanger around your water heater.
See Sections 2-11 and 8-8.
2003 Itasca Sunova Owner's ManualLook here for all of the manuals and diagrams that are available to you from Winnebago.
Winnebago Industries Manuals and Diagrams
